iiwan
6 years agoHow to tell quartus for multiple clock
I have part of my disign for Stratix V, that works on rx_std_clkout and tx_std_clkout from Transceiver Native PHY IP core, and dynamically change speed via Transceiver Reconfigurator IP core. I use w...
CheepinC_altera
6 years agoHi,
Just to ensure we are on the same page, would you mind to further elaborate on the "quartus not compile design well" observation? Just wonder if you are referring to timing constraining your design which will be working on different speed?
Chee Pin
iiwan
6 years agoNo, I mean, that, at start speed of Native Phy speed 2,5Gb and rx and tx clkout has freq 62,5 Mhz, than I dynamically reconfigure to 5Gb and 10Gb, so my tx and rx clkout has 125 and 250 Mhz. But I think, Quartus compile good only for 62,5 Mhz, and when I change speed, it works not good as I expected. So question is, how to tell Quartus in my project, that my modules have to work good at every clk, 62,5 , 125, 250 Mhz.
P.S. I think, if I set at beginning speed 10Gb and then downgrade to 2,5Gb, its not good idea too.
