HKühn
6 years agoHow to Simulate a ROM initialized with a *.if File is Modelsim-Altera.
Hello, I am using Quartus Prime Lite Edition to programm a MAX10 (10M08SAU169C8G). I wanted to add a ROM which is initialized with a .mif File. The design compiles and ROM works fine on the FPGA. I a...
AnandRaj_S_Intel
6 years agoHi Holger,
Your ROM design is not having a write-enable(wren) signal?
The test bench is not correct, You have to consider read and write latency.
After giving address waiting for at least 2 clock cycles for read or write from the memory.
For example, you can refer below project which can be run using do,do file or testbench.do file.
Anand
