CAlex
Contributor
3 years agoHow to set the SPL and the sdimage correctly with baremetal applications
Hi, I'm working on cycloneV soc with the newest soceds 20.1 so the bsp-editor cant be used as a uboot setting. I want to start the baremetal application from a sdcard. SDimage: A2: u-boot-wit...
tehjingy_Altera
3 years agoHi Alex
You use this command to flash the binary that you created into the QSPI Flash of the board.
This command is to be run in your development PC with the nios2_command_shell.sh resources.
You can refer to the steps to flash the QSPI here:
