How to set the SPL and the sdimage correctly with baremetal applications
Hi Alex
I am using the hwlibs examples located here:
https://www.rocketboards.org/foswiki/Documentation/HWLib#Running_Cyclone_V_HWLib_Example
Please find the binaries attached.
If you could also send me your copy that would be great.
I see that the steps that you are using is slightly different from mine.
The steps of creating the binary, i am using the command below:
"arm-eabi-objcopy -O binary application.elf application.bin"
The application should be in .elf instead of .axf.
You can change the Makefile line 54 to "ELF := application.elf".
Jingyang, Teh
Sure, I'll attach my code to you, one is for arm ds, and another is for sdimage.
Meanwhile I'll try to use elf instead of axf, although I think there is no difference between two binaries.
Reguards.
