CAlex
Contributor
3 years agoHow to set the SPL and the sdimage correctly with baremetal applications
Hi, I'm working on cycloneV soc with the newest soceds 20.1 so the bsp-editor cant be used as a uboot setting. I want to start the baremetal application from a sdcard. SDimage: A2: u-boot-wit...
tehjingy_Altera
3 years agoHi Alex
Your SPL logs look a bit different from the standard SPL.
What changes did you made to the SPL? Did you follow the steps in RocketBoard to build the SPL?
Could you give me some time in trying to boot the baremetal application from SD Card?
I have tried the flow of booting from QSPI but not with SD Card.
Just to confirm you build your application using the flow describe in the HWLIBS RocketBoard article right?
For the logs in the previous comment, did the SPL automatically reads the P3_Ex.bin or did you made some changes to read the P3_Ex.bin?
Is it possible for you to share the env variable of your uboot environment?
Jingyang, Teh
