16 years agoHow to run crystal??
I have The Connor-Winfield CS-023 3.2x2.5mm Surface Mount Crystal.It has 4 pins.Datasheet shows to ground 1,4 pins.I have read somewhere that for 4 pin crystal one dnt need an external electronic...
16 years agoI have found an inverter 74LVC1Gx04 for my 114.25Mhz crystal...will they work with each other? What else i have to connect except load capacitances and resistor.Any issues?
