15 years agohow to read data from FIFO in SOPC
hi,BadOmen or other gurus: I write a SOPC component which is connected to AVALON bus.the custom component mainly consist of FIFO,I want to write a large bulk of datas in it and then read th...
15 years agoI change the baseaddress of the SOPC component in SOPC builder manually,
for example: Error: pb_cpu_to_io/m1:Base Address for uart_RS232_LRF must be a multiple of its span 0x40. you can change uart_RS232_LRF baseaddress which can be divided by 0x40
