YBoro's avatar
YBoro
7 years ago
How To Program Only The Nios Software to Flash Memory?
Hi, I want to program the flash memory directly, only the elf file from the nios without changing the .sof file and prevent the long compilation of the quartus in order to combine the elf and sof. If I change only the C source There is any way to program only the changing of the nios program into flash memory (outside of the ALTERA) and in power cycle the FPGA will loaded with the same .sof file but with new .elf fille?
