SERMASWATHIKA
Contributor
2 years agohow to program epcq device on starter vino kit of cyclone v gt device
Hi Team, We are using cyclone v gt eval kit. we tried to check the flash programming of our design in eval board. we create the design with nios,ocm,jtag,serial flash controller ip(legacy...
NurAiman_M_Intel
2 years agoHi,
-quartus_pgm command can be use to program EPCQ.
-Can you try to use latest quartus version 23.1?
-Make sure to run as administrator: Quartus Tool's "Windows Authorization" to Administrator
-Can you share your design file in .qar so we can reproduce the error?
-You are using windows or Linux?
Aiman
SERMASWATHIKA
Contributor
2 years agoHi ,
I have attached the project zip file in this attachment, facing access violation error when we used to program epcq with flash files.
Please check and give your response.
