SERMASWATHIKA
Contributor
2 years agohow to program epcq device on starter vino kit of cyclone v gt device
Hi Team, We are using cyclone v gt eval kit. we tried to check the flash programming of our design in eval board. we create the design with nios,ocm,jtag,serial flash controller ip(legacy...
NurAiman_M_Intel
2 years agoHi,
-quartus_pgm command can be use to program EPCQ.
-Can you try to use latest quartus version 23.1?
-Make sure to run as administrator: Quartus Tool's "Windows Authorization" to Administrator
-Can you share your design file in .qar so we can reproduce the error?
-You are using windows or Linux?
Aiman
- SERMASWATHIKA2 years ago
Contributor
i am using windows not linux
quartus tool windows authorization --i will check
i will share the project archieve on monday
Contributor
Hi ,
I have attached the project zip file in this attachment, facing access violation error when we used to program epcq with flash files.
Please check and give your response.
Contributor
can you please respond for this?
