SERMASWATHIKA
Contributor
2 years agohow to program epcq device on starter vino kit of cyclone v gt device
Hi Team, We are using cyclone v gt eval kit. we tried to check the flash programming of our design in eval board. we create the design with nios,ocm,jtag,serial flash controller ip(legacy...
SERMASWATHIKA
Contributor
2 years agoHi ,
initially i have used "nios2-flash-programmer.exe --epcs --base=0x0 epcscode_test_mem_core.flash" this command to program the epcq in 22.1 quartus tool.
At that time i got epcs signature read failiure error. After that i get to know that, nios2-flash command is EOL.
So i have tried quartus_pgm command to program the epcq now.
In that programming command, i got this following error:
attahced the screenshot for clearview .
Please clear one point that can i use this quartus_pgm command to program the epcq?
this can be used in cyclone v gt kit which uses Max II for configuration
SERMASWATHIKA
Contributor
2 years agodo you have any response for the above information? if any please respond
