16 years agoHow to program an I/O as a open drain on MAXII Micro Kit by using Quartus II?
Hi, Are there anyone knows how to program an I/O as a open drain on MAXII Micro Kit by using Quartus II? I saw the MAXII device handbook. The MAXII supports a function of open drain for th...
16 years agoI've seen a post which uses a command as below in QSF.
set_instance_assignment -name AUTO_OPEN_DRAIN_PINS ON -to xxxxx I've tried. I, however, couldn't find any difference on the Quartus II. How can I know if the pins have been programmed as a open drain output? Thanks. Peter Chang
