BQi
6 years agoHow to merge the reconfig module in project and finish the complication?
Customer name Beijing run 1SM21BH2F53E2VG,quartus pro 19.3,H tile We have the different rate in receiver channel and transmit channel, it is simplex mode in the same time, the 48 transceivers need...
BQi
6 years ago1.Yes, Both TX and RX would be used the same GXT in 25Gbps, you can revise the design or delete the RX.
2.If you think these option which would lead to unmerge, you can delete them. then try the project.
3.I suggest you can delete the rx directly then try. thanks
