BQi
6 years agoHow to merge the reconfig module in project and finish the complication?
Customer name Beijing run 1SM21BH2F53E2VG,quartus pro 19.3,H tile We have the different rate in receiver channel and transmit channel, it is simplex mode in the same time, the 48 transceivers need...
CheepinC_altera
6 years agoHi,
Sorry for the delay as this case was just routed to me. As I understand it, you have simple instances of TX and RX and would like to merge the reconfig interfaces. For your information, to merge the reconfiguration interfaces for different instances, you would need to use the "XCVR_RECONFIG_GROUP" QSF assignment. For further details on the requirement and limitation, you may refer to the Intel® Stratix® 10 L- and H-Tile Transceiver PHY User Guide -> "Rules for Merging Reconfiguration Interfaces Across Multiple IP Cores" section for further details.
Chee Pin
