how to link everything together?
- 5 years ago
Hi David,
Regarding the error message, I think this is due to different versions of the Intel Quartus Prime software that you are using and the version used to create the example. Some of the qsf settings in older version are not supported in the newer version.
For reference design, you may find in the link below. User Guides and Reference Designs > Reference design.
Besides the reference design, you may also generate some simple example designs using the IP parameter setting GUI.
KhaiY
Hi David,
KhaiY
Hi KhaiY,
After I click Edit the Qsys of the top module, I got the following errors, I think to fully understand this problems, I need to carefully read the emif IP and dma IP user manual, any quick solution.
Error: top.DUT.dma_rd_master/emif_0.ctrl_amm_0: Missing connection start (try "Remove Dangling Connections")
Error: top.DUT.dma_rd_master/DUT.rd_dts_slave: Missing connection start (try "Remove Dangling Connections")
Error: top.DUT.dma_rd_master/DUT.rd_dts_slave: Missing connection end (try "Remove Dangling Connections")
Error: top.DUT.dma_rd_master/DUT.wr_dts_slave: Missing connection start (try "Remove Dangling Connections")
Error: top.DUT.dma_rd_master/DUT.wr_dts_slave: Missing connection end (try "Remove Dangling Connections")
Error: top.DUT.dma_wr_master/mm_clock_crossing_bridge_0.s0: Missing connection start (try "Remove Dangling Connections")
Error: top.DUT.rd_dcm_master/DUT.txs: Missing connection start (try "Remove Dangling Connections")
Error: top.DUT.rd_dcm_master/DUT.txs: Missing connection end (try "Remove Dangling Connections")
Error: top.DUT.rxm_bar4/emif_0.ctrl_amm_0: Missing connection start (try "Remove Dangling Connections")
Error: top.DUT.wr_dcm_master/DUT.txs: Missing connection start (try "Remove Dangling Connections")
Error: top.DUT.wr_dcm_master/DUT.txs: Missing connection end (try "Remove Dangling Connections")
Error: top.DUT.app_nreset_status/clk_0.clk_in_reset: Missing connection start (try "Remove Dangling Connections")
Error: top.DUT.app_nreset_status/emif_0.global_reset_n: Missing connection start (try "Remove Dangling Connections")
Error: top.DUT.app_nreset_status/mm_clock_crossing_bridge_0.s0_reset: Missing connection start (try "Remove Dangling Connections")
Error: top.DUT: DUT.pld_clk must be connected to a clock output
Error: top.DUT.dma_wr_master: Data width must be of power of two and between 8 and 4096
I am just running the example project, why there are still so many errors during loading?
Best,
David
