How to get Quartus (19.1) and the simulator running
I am trying to run this example (see url link) to get acquainted with Quartus and the simulator. https://www.intel.com/content/www/us/en/programmable/documentation/aym1499789502823.html
But running the compiler I am always getting this error: Error (12024): WYSIWYG primitive "general[0].gpll" is not compatible with the current device family.
I tried the following devices (MAX 10, Cyclone 10 LP and Cyclone IV), but the problem still exists. I am using: Quartus Prime Version 19.1 Build 670 09/22/2019 SJ Lite Edition. Maybe the Lite edition does not apply, I don't know.
Any idea what I am doing wrong?
- KennyT_altera
What is the IP that you are using for your design? can you attached your design.qar here to take a look?
- PHeri1
I am very new to Intel FPGA so I do not quit understand what you mean with IP in this example.
The example consists of a complete project in a zip file. There is no design.qar file.
- sstrell
The document doesn't say it, unfortunately, but the project file (.qsf) indicates that this design uses a Cyclone V device. Make sure you have Cyclone V devices installed before opening the project.
#iwork4intel
- PHeri1
Thank you, problem solved
- Bastien18
I am currently trying to re-compile a project previously compiled for a cyclone V but for a cyclone 10 and I get the same error. I'm quite new on this topic and maybe just changing device in the device setting is not sufficient to re-compile it.
I understand it has to do with primitives related to specific family but I can't find information on how to adapt it to work properly on a different family.
If somebody could enlighten me I would appreciate.
