16 years agoHow to get Data from a Verilogfile to the NIOS II Softcore
Hi i m using the NEEK Board and want to know if there is an Easy way to access the SRAM on it from Hard and Software. here the explain of my needs. The SRAM is initializiest in verilog and...
16 years ago --- Quote Start --- problem is that the Verilog Function uses the SRAM to Store Data and change Data and use the Data to do more other things --- Quote End --- I don't see what the problem is. If the SRAM is an Avalon slave and your custom verilog and NIOS CPU are both masters, both your custom verilog and NIOS CPU can access the SRAM. SOPC builder will automatically provide arbitration logic.
