16 years agoHow to get Data from a Verilogfile to the NIOS II Softcore
Hi i m using the NEEK Board and want to know if there is an Easy way to access the SRAM on it from Hard and Software. here the explain of my needs. The SRAM is initializiest in verilog and...
16 years agomhh good idea
problem is that the Verilog Function uses the SRAM to Store Data and change Data and use the Data to do more other things :D but its a idea maybe i should try that ! Thanks
