JBuch's avatar
JBuch
6 years ago
How to get *.jic to work on Cyclone 10 lp Dev board
After connecting a USB Blaster to the dev board's JTAG connector and setting dip(4) to off, I added the flash-loader ip to my simple dff design. I synthesized everything and created a *jic file to the appropriate components for this dev board. Using the programmer set for USB BLASTER and the jic file loaded, the upload failed. I've added pictures to illustrate what occurred. I know my setup is correct because I programmed the dev board using the *sof file and not bothered with the flash loading stuff. I thought I followed everything in an370 correctly, but I'm missing something. Any help would be greatly appreciated.
  • JBuch's avatar
    JBuch
    Opps, the dip switch was not seated all the way. It now works.
    Sorry.
    It works, I can now use this board!
    Thank you for your help.
