JBuch
6 years agoHow to get *.jic to work on Cyclone 10 lp Dev board
After connecting a USB Blaster to the dev board's JTAG connector and setting dip(4) to off, I added the flash-loader ip to my simple dff design. I synthesized everything and created a *jic file to th...
AnandRaj_S_Intel
6 years agoHi,
Have you changed the switch state(SW1 BYPASS) ???
If sw setting are correct than i will sespect the .jic
Which epcq device is being used.
If you are using epcq64 than try below file to load.
Anand
