14 years agoHow to generate 30 PWM singals using MAX II starter kit
I want a dsp2812 to generate three PWM signals and a I/O singal and input them to the MAX II starter kit. and is there a neccessity to make a middle circuit between two kits? Also, I want to generat...
14 years agoI'm not familiar with the TI DSP details, particularly I'm unable to locate a dsezd2812 schematic to understand the available IO interconnect option. Thus I don't know, if you can easily output a derived clock.
On the MAXII side, there should be no problem to operate the design from an external supplied clock instead of the on-board clock oscillator. This can save the effort for synchronizing the input signals from DSP. Because MAXII has no clock managment options, the clock frequency has to be suitable to operate the design. MAXII logic resources are limited, so the "division of work" between both digital chips should be well considered. Are you already clear about the algorithm to generate the multi-level PWM signals?
