14 years agoHow to generate 30 PWM singals using MAX II starter kit
I want a dsp2812 to generate three PWM signals and a I/O singal and input them to the MAX II starter kit. and is there a neccessity to make a middle circuit between two kits? Also, I want to generat...
14 years agoas you are referring to a particular eval kit, itt would be appropriate to tell the exact type or better provide a link to the documentation. To design the link between both boards, you should know about the required data throughput.
A common clock can simplify the interface.
