MSteg2
7 years agoHow to fix "OutOfMemoryError: Java heap space" error
We are building using the Quartus 11.1sp1 version (yes that is old but we have no reason to upgrade at this time) I found where I can remove “DEAD” codespace by adding this to my Compiler options: ...
MEIYAN_L_Intel
7 years agoHi,
May i know the BSP setting?
By clicking as below:
-right click the bsp project
-click Nios
-click BSP editor
The steps mentioned as below:
May you try to screenshot the main screen and linker script screen of the window open?
MSteg2
7 years agoAttached is my “Settings.bsp” that you edit with the BSP Editor (and the settings.tcl if you need that), please tell me EXACTLY what needs to change with a step-by-step process if needed
I haven’t “messed” with my BSP settings for years!
Matthew B. Steger | Sr. Software Engineer
T +1.847.871.1177 | M +1.630.254.2243
Genfare | 800 Arthur Ave | Elk Grove Village IL 60007
Genfare.com<https://www.genfare.com/> | LinkedIn<https://www.linkedin.com/company/genfare> | Customer Care<https://www.genfare.com/customer-care/>
The information contained in this electronic mail transmission is intended by SPX Corporation for the use of the named individual or entity to which it is directed and may contain information that is confidential or privileged. If you have received this electronic mail transmission in error, please delete it from your system without copying or forwarding it, and notify the sender of the error by reply email so that the sender’s address records can be corrected.
