3 years agoHow to correctly read data from FIFO on HPS and send it out through HPS Ethernet
I am a novice. I have two clone V soc boards, and I generated some video data on the FPGA side of one of them and sent it to the HPS side through the H2F AXI bus. I want to send it to the second boar...
- 3 years ago
We only have two examples, but on old version so you can use them as references, unfortunately we do not have the latest version for this:
https://www.rocketboards.org/foswiki/Projects/CycloneVRGMIIExampleDesign
2258432
3 years agoI changed the FIFO to a dual port FIFO, and then used the same code to read the data in the FIFO. Everything looked normal. But when I added the function to send data, the reading of the data seemed to run counter to the correct result.
FIFO has a depth of 2048 and a width of 32. qsys2reading datasending data
/* code for sending data */ #include <stdio.h> #include <fcntl.h> #include <sys/mman.h> #include <stdint.h> #include <unistd.h> #include <string.h> #include <arpa/inet.h> #include <sys/socket.h> #include <netinet/in.h> #define HW_REGS_BASE (0xC0000000) #define HW_REGS_SPAN (0x04000000) #define ALT_H2F_OFST (0xFF500000) #define HW_REGS_MASK (HW_REGS_SPAN - 1) #define LED_PIO_OFFSET (0x00000408) #define DEST_IP_ADDR "192.168.0.11" #define DEST_PORT 1234 int main() { int fd; void *h2f_axi_base; void *led_pio_addr; int sock; struct sockaddr_in dest_addr; fd = open("/dev/mem", O_RDWR | O_SYNC); if (fd == -1) { perror("could not open /dev/mem\n"); return 1; } h2f_axi_base = mmap(NULL, HW_REGS_SPAN, PROT_READ | PROT_WRITE, MAP_SHARED, fd, HW_REGS_BASE); if (h2f_axi_base == MAP_FAILED) { perror("could not mirror the H2F AXI address\n"); close(fd); return 1; } led_pio_addr = h2f_axi_base + ((unsigned long)(ALT_H2F_OFST + LED_PIO_OFFSET) & (unsigned long)(HW_REGS_MASK)); sock = socket(AF_INET, SOCK_DGRAM, 0); if (sock == -1) { perror("socket creation failed\n"); munmap(h2f_axi_base, HW_REGS_SPAN); close(fd); return 1; } memset(&dest_addr, 0, sizeof(dest_addr)); dest_addr.sin_family = AF_INET; dest_addr.sin_port = htons(DEST_PORT); if (inet_pton(AF_INET, DEST_IP_ADDR, &(dest_addr.sin_addr)) <= 0) { perror("inet_pton failed\n"); munmap(h2f_axi_base, HW_REGS_SPAN); close(sock); close(fd); return 1; } while (1) { uint32_t data = *((volatile uint32_t *)led_pio_addr); if (sendto(sock, &data, sizeof(data), 0, (struct sockaddr *)&dest_addr, sizeof(dest_addr)) == -1) { perror("sendto failed\n"); break; } } close(sock); munmap(h2f_axi_base, HW_REGS_SPAN); close(fd); return 0; }
