shvlad
7 years agoHow to configure DSP block in "three 9x9 multipliers" mode?
Hi everyone Please help me configure DSP block in "three 9x9 multipliers" mode. I have a Cyclone V family chip, I've read this document https://www.intel.com/content/dam/www/programmable/us/en/pdfs/...
CheepinC_altera
7 years agoHi,
Thanks for sharing the QAR. Based on my understanding, the way 1 seems to be the right way for the implementation. I am able to replicate the observation of 3 DSP blocks being used in compilation. For your information, as I added logic lock region with only 1 DSP in the chip planner, and assign your design to it, the compilation is able to fit the three 9x9 multipliers into a single DSP block.
For your information, generally if there are still sufficient DSP blocks in the device, the compilation will choose to utilize more DSP blocks for better timing and performance. Fitter will only try to pack into a single DSP block when there is limited DSP resources.
Chee Pin
shvlad
7 years agoYour answer is totally right!
I created this code
`timescale 1ns / 1ns
(* multstyle = "dsp" *)
module mux_9x9
parameter L = 25
input logic [8:0] x_0[L],
input logic [8:0] x_1[L],
input logic [8:0] x_2[L],
input logic [8:0] y_0[L],
input logic [8:0] y_1[L],
input logic [8:0] y_2[L],
output logic [17:0] p_0[L],
output logic [17:0] p_1[L],
output logic [17:0] p_2[L]
genvar i;
generate
for( i = 0; i < L; i++ )
begin:MULT
assign {p_0[i],p_1[i],p_2[i]} = {x_0[i]*y_0[i],x_1[i]*y_1[i],x_2[i]*y_2[i]};
end
endgenerate
endmoduleQuartus places three multi to one DSP when it doesn't have enough DSP (just change parameter "L").
