HungLam
6 years agoHow to change default clock frequency in A10 fpga dev kit
I am using A10 FPGA dev kit, by default clock generator IC - U14 SI5338 generates clock[3..0] = 302.083333MHz, 625MHz, 625MHz, 100Mhz.
I would like to change clock output 1 from 625MHz to 125Mhz as reference clock for xcvr in FMCA.
I just used BTS tool to change it to 125Mhz, but the configuration lost when power-down. It still keeps 625Mhz after re-start.
Is it possible to change it to 125Mhz without the reconfiguration every power-on.
Thanks!
1 Reply
- AR_A_Intel
Welcome to INTEL forum. Regrettably, it is not possible to change default clock frequency to 125Mhz without the reconfiguration.
