14 years agoHow to access SRAM on CycloneIII dev kit - not via nios !
Hi, I've been searching the forums for quite some time, and couldn't find an answer to my problem. I'm trying to access the ssram on the CycloneIII Starter kit board. however, from the SSR...
14 years agothank you for the reply.
let me rephrase the issue. I don't want to write and read simultaneously. it's filling the memory first, and then read it. I'm trying to use the test code: ///////////////////////////////////////////// always @(posedge osc_clk or negedge reset_n) if (~reset_n) begin ram_cnt <= 0; end else begin ram_cnt <= ram_cnt + 1; end assign ssram_adsc_n = 1'b0; assign ssram_ce_n = 1'b0; assign flash_ssram_a = ram_cnt[9:1]; assign ssram_bwe_n = ram_cnt[10]; assign ssram_oe_n = ~ram_cnt[10]; assign flash_ssram_d = (ssram_oe_n) ? ram_cnt[9:1] : 32'bZ; ///////////////////////////////////////////// the code should simply fill each address with a consecutive number. however, although the write sequence is 0,1,2,3,4,5,6,7,8,9,10,11 (inc per clk). I see that on the output the data lines show -1,-1,-1,-1,3,3,3,3,7,7,7,7,9,9,9,9,11,11,11,11 etc. all I need is an example of code (Verilog or VHDL, not C) that will allow writing of a streaming data (60MHz, if it is relevant) into the SSRAM. and an example of how to read it in a stream after than. thanks
