SKacc
6 years agoHow does FPGA reconfigures if it doesn't use nCONFIG pin in Arria V FPGA?
Hi Low-to-high transition on nCONFIG reconfigures the FPGA. Pin connection guidelines says to connect 10K pull up or leave unconnected on nCONFIG pin for Arria V FPGA. If it so, how does it reconfig...
ShafiqY_Intel
6 years agoHi SKacc,
If you does not use nCONFIG pin to reconfigure Arria V FPGA, you can power cycle the board to reconfigure Arria V device.
Once you power OFF & ON the board, nCONFIG will trasition Low-to-High again.
SKacc
6 years agoHi Shafiq
Thanks for the response.
Srikanth Kacchu
