How do I restore/reset Arria 10 SoC FPGA development boards that are not accessible via JTAG anymore?
Hi RBens,
Just would like to clarify that the JTAG server programming is having problem on the board but the on-board USB Blaster is working fine?
Speaking about board reflashed/restored/reset, do you want to program MAX V with default hardware programming file? If it so, you may find the programming file available in Arria 10 SX SoC Package Installer. It is located in directory “..\arria10_10as066n3f40_soc_v15.1.2\examples\max5\PRD”.
Thank You.
YL
- JET602006 years ago
Contributor
Hello ,
Is it possile to get the the source code of system max V ( only binary system_max5.pof exists in Dev Kit), which uses to control the power sequence for the Arria 10 SoC Dev Kit ?
We're working on a customer design with A10Soc , and they want to use MAX V as well on their customer board.
Any way to get ? Thanks a lot
