How do I get started?
I have a MAX10 10M08 Eva board and a USB Blaster programming device. I have installed Quartus II and written a short verilog test program but cannot detect the USB Blaster or the Evaluation board. Where are the helpful getting started guides and tutorials for Max 10?
- Vicky1
Please check the below details,
- Ensure correct device part number available on Evaluation kit & selected in Quartus tool both are same.
- Ensure the installation of USB-blaster device drivers
- Ensure the factory default switch and jumper settings
Refer the 'Chapter 2 &3' from below User guide,
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug_max10_eval_10m80.pdf
For more details about MAX10 Evaluation kit refer the link below,
https://www.intel.com/content/www/us/en/programmable/products/boards_and_kits/dev-kits/altera/kit-max-10-evaluation.html
Vicky
- JPott5
Hi Vicky, Thanks for your reply.
1.Ensure correct device part number available on Evaluation kit & selected in Quartus tool both are same. - Yes this is done I am using Quartus Prime Lite V18.1, I have created a new project using the LED_Flash_all template which specifies the correct device part number 10M08SAE144C8GES.
2. Ensure the installation of USB-blaster device drivers -The device driver appears in the Device Manager as Altera USB Blaster - working OK
3. Ensure the factory default switch and jumper settings - Confirmed OK.
When I open the programmer in Quartus the correct FPGA device is shown. However when I click on Hardware Setup and attempt to Add Hardware I am only able to select an EthernetBlaster. please see attached JPG file.
Does this mean that Quartus is not recognising the windows driver for the Altera USB Blaster or do I need to configure the tool to tell it to look for a USB blaster?
John
- Vicky1
Could you please check 'Currently selected hardware' drop down menu for USB- Blaster as shown below?
provide 'device manager' screenshot to ensure USB- Blaster installed successfully.
Vicky
- JPott5
Under the Currently selected hardware drop down menu USB-Blaster is not shown. unfortunately I cant take a screenshot showing that drop down open.
Attached you will find the screenshot of Device manager showing the USB-Blaster entry.
I have also gone through the troubleshooting suggestions in the, 'ug_usb_blstr Intel FPGA download cable user guide.pdf' document.
Here is the response to the jtagconfig --serverinfo command:
C:\altera\16.0\quartus\bin64>jtagconfig --serverinfo
Installed JTAG server is 'C:\altera\16.0\quartus\bin64\jtagserver.exe'
Service manager reports server is running
Server reports path: C:\altera\16.0\quartus\bin64\jtagserver.exe
Server reports version: Version 16.0.0 Build 211 04/27/2016 SJ Standard Edition
Remote clients are disabled (no password)
No JTAG hardware available
John
- JPott5
Vicky,
I am also struggling to work out what support is available to me, for example when I try to access training courses such as The Quartus Software Interactive Tutorial I either get :
Resource at '/content/altera-www/global/en_us/index/support/training/course/odsw1050.html' not found: No resource found
RequestURI=/content/altera-www/global/en_us/index/support/training/course/odsw1050.html
Servlet= /apps/sling/servlet/errorhandler/404.jsp
ApacheSling/2.4 (jetty/9.2.17.v20160517, Java HotSpot(TM) 64-Bit Server VM 1.8.0_162, Linux 4.4.21-69-default amd64)
OR The I get the attached response when I attempt to register for a course.
Its really blocking ability to move forward with evaluating the Max 10 for a new project.
- Vicky1
As mentioned over there, please try opening the page in a new browser window(Like IE, Chrome,Mozilla etc) after clearing your browser cache and cookies. If still issue persists you can email or raise the ticket at provided details over there.
Vicky
- JPott5
This has been very helpful.
I would add that watching the "How to begin a Simple FPGA Design" video on YouTube is a very simple starter to create a project with Block schematic, creating schematic symbols from your HDL code and use of IP.
