How do I get started?
Hi Vicky, Thanks for your reply.
1.Ensure correct device part number available on Evaluation kit & selected in Quartus tool both are same. - Yes this is done I am using Quartus Prime Lite V18.1, I have created a new project using the LED_Flash_all template which specifies the correct device part number 10M08SAE144C8GES.
2. Ensure the installation of USB-blaster device drivers -The device driver appears in the Device Manager as Altera USB Blaster - working OK
3. Ensure the factory default switch and jumper settings - Confirmed OK.
When I open the programmer in Quartus the correct FPGA device is shown. However when I click on Hardware Setup and attempt to Add Hardware I am only able to select an EthernetBlaster. please see attached JPG file.
Does this mean that Quartus is not recognising the windows driver for the Altera USB Blaster or do I need to configure the tool to tell it to look for a USB blaster?
John
