ArjunTechM's avatar
ArjunTechM
4 years ago
How can i use differential to Single Clock input for Agilex FPGA Device using Intel PRO 21.4 Tools
I am currently working with Agilex FPGA Device for one of the NVM Storage device project.
I need to use external differential input clocks which are to be used for different interfaces.
I need to convert them into single and use internally.
Can i have any Differential to Single clock convertor IP available in IntelPRO 21.4 Version tool.
Also am in need of clock buffer IP to use for the same project.
Please suggest me proper IP to use these.
Thanks inadvance.
Best Regards
Ram
  • Farabi_Altera's avatar
    Farabi_Altera
    To use diff signal to single IO, you just tap either P or N of the diff pin, then it will become single ended signal. You dont have to use any IP to convert it.
    regards,
    Farabi
    • ArjunTechM's avatar
      ArjunTechM
      Thank you Farabi.
      One more doubt , How can i use buffer IP Whether it may be Clock Buffer or IO Buffer in the Intel PRO Tool
      Best Regards
      Ram
