ArjunTechM
4 years agoHow can i use differential to Single Clock input for Agilex FPGA Device using Intel PRO 21.4 Tools
I am currently working with Agilex FPGA Device for one of the NVM Storage device project.
I need to use external differential input clocks which are to be used for different interfaces.
I need to...
- 4 years ago
Hello Ram,
You may find it in the IP Catalog inside the Intel Quartus Prime Pro. You also can refer to the documentation regarding the Clock Control Intel® FPGA IP Core.
Aqid Ayman
Farabi_Altera
4 years agoHello,
To use diff signal to single IO, you just tap either P or N of the diff pin, then it will become single ended signal. You dont have to use any IP to convert it.
regards,
Farabi
ArjunTechM
4 years agoThank you Farabi.
One more doubt , How can i use buffer IP Whether it may be Clock Buffer or IO Buffer in the Intel PRO Tool
Best Regards
Ram
