KSUNG10
6 years agoHow can i resolve ploblem "Error (16353): Expected the Max 10 device at index 1 to be of type analog, but detected device of type compact instead. Ensure that you are using the correct programming file." Error
I used MAX10 FPGA Device 10M50DAF484C7G configuration with Altera USB Blaster. How can i resolve ploblem "Error (16353): Expected the Max 10 device at index 1 to be of type analog, but detected devi...
YuanLi_S_Intel
6 years agoHi Kim,
The error message indicates that you are not using the correct programming file for the configuration. Can i have full picture of your setup?
- What configuration scheme you are using.
- How many devices in the board?
- what is the programming file generated and programmed into this?
Thank You.
