How can I connect between Stratix 10 DX Development Kit and PCIe devices through SlimSAS cable
I have a Stratix 10 DX FPGA Dev. Board.
I would like to connect between the board and PCIe device through SlimSAS connector.
I have seen that one SlimSAS connector for TX and another SlimSAS connector for RX.
This is not compatible SNIA cable for PCIe 4 lane or 8 lane connection.
As the SNIA spec., one SlimSAS cable use TX and RX channels.
If Intel can suggest how to use P-tile for PCIe device through SlimSAS, it will be helpful for me.
YongIn
Hi
We have not hear from you and this Case is idling. It is not recommended to idle for too long.
Therefore following our support policy, I have to put this case in close status. My apologies if any inconvenience cause
Hence, This thread will be transitioned to community support.
If you have a new question, feel free to open a new thread to get support from Intel experts.
Otherwise, the community users will continue to help you on this thread. Thank you
If you feel your support experience was less than a 9 or 10,
please allow me to correct it before closing or let me know the cause so that I may improve your future support experience.
Wincent_Intel
- Wincent_Altera
For SlimSas connector you may refer to the user guide below under session A.8
https://www.mouser.com/datasheet/2/612/ug_s10_dx_fpga_dev_kit-1771948.pdf
Hope this answer your question.
Wei Chuan
- YongInLee
Thanks for your answer.
I had checked that information.
However the pin map tx, rx does not match trivial PCIe connection through SlimsSAS cable 8i.
Do I need to make daughter board for converting pin map?
YongIn
- Wincent_Altera
To be honest I not familiar with Slimsas.
My expert of support is only for FPGA board and its design example.
You may try the connection as what you suggested.
But detail, I do suggest you to reach out the Slimsas support.
Wei Chuan
- Wincent_Altera
I wish to follow up with you about this case.
Do you have any further questions on this matter ?
Else I would like to have your permission to close this forum ticket
Wincent_Intel
- Wincent_Altera
Hi
Wincent_Intel
