How can I connect between Stratix 10 DX Development Kit and PCIe devices through SlimSAS cable
- 3 years ago
Hi
We have not hear from you and this Case is idling. It is not recommended to idle for too long.
Therefore following our support policy, I have to put this case in close status. My apologies if any inconvenience cause
Hence, This thread will be transitioned to community support.
If you have a new question, feel free to open a new thread to get support from Intel experts.
Otherwise, the community users will continue to help you on this thread. Thank you
If you feel your support experience was less than a 9 or 10,
please allow me to correct it before closing or let me know the cause so that I may improve your future support experience.
Wincent_Intel
For SlimSas connector you may refer to the user guide below under session A.8
https://www.mouser.com/datasheet/2/612/ug_s10_dx_fpga_dev_kit-1771948.pdf
Hope this answer your question.
Wei Chuan
I had checked that information.
However the pin map tx, rx does not match trivial PCIe connection through SlimsSAS cable 8i.
Do I need to make daughter board for converting pin map?
YongIn
