RLee42
7 years agoHow can I assign a node is not a clock for TimeQuest
Hi, Quartus TimeQuest infers a PIN as a clock because I need to use it as the way of a clock for some reason. However, it's a not a clock and mostly used as a data in the design. I couldn't find...
RLee42
7 years agoHi Ivan,
Thank you for your information.
Sorry that I didn't describe it clearly.
For 1, thank you for letting me confirm there is no "not a clock" assignment any more.
For 2, the net signal_clk and signal_data couldn't be found as they were synthesized away. I could use synthesis attribute to avoid this which solved my issue.
Here are RTL code I mentioned above, which might be better to show as below:
input logic signal;
logic signal_clk;
logic signal_data;
assign signal_clk = signal;
assign signal_data = signal;
Cheers,
Ross
