Help with something on board
- 2 years ago
That is JP6. It is a 2pin header that allows you to supply 5V power to the board thru it. It is input to the board only.
The connector is diode-or'ed with the USB 5V power input so that power to the board can come from either source (or both).
Most users will just supply 5V power to the board thru the USB cable which also supports the USB Blaster programming functionality.
Thank you for your explanation and your time!
