17 years agoHelp required on Ethernet with FPGA
Hi .. I'm a student and I'm working on a project which involves a design that has NiOS II processor, DDRSDRAM, SSRAM, a custom Ethernet MAC and other components and I've to run an applicat...
17 years agoSignals with an 'unknown' direction are usually signals that have some assignments (such as location in the pin planner, i/o voltage...) but that don't exist in the top level design.
You should check for each one of them if it's a pin that you need in your design or not. If you don't need it, you can either remove the assignments (only possible in the assignment editor IIRC) or create a port for it on your top level design (and give it a default value if it's an output).
