18 years agoHelp needed about the DE2 Audio Codec
-------------------------------------------------------------------------------- I set up everything as in the DE2 manual, and use the reference design to play music(48KHZ,wav). But why there i...
17 years ago1.Did you use i2c to config Audio Core? When add an audio core in SOPC, all parameter are filled so I guest that there's no need to use i2c to config.
2. I used default setting (48Khz samplerate, clk 18432000,. 16bit data, 2 channel). In according to Manual, data registers are BASE+8, and BASE+12 Then I coded: IOWR(AUDIO_0_BASE,8,#value) IOWR(AUDIO_0_BASE,12,#value) nothing happens!!!! plz tell me why
