18 years agoHelp needed about the DE2 Audio Codec
-------------------------------------------------------------------------------- I set up everything as in the DE2 manual, and use the reference design to play music(48KHZ,wav). But why there i...
18 years agoI have DE2 with 2C35 and not sure DE2-70 has the same HDL file, but… Please try to edit “I2C_AV_Config.v” and replace the line
A_PATH_CTRL : LUT_DATA <= 16'h08F8; With A_PATH_CTRL : LUT_DATA <= 16'h08D0; Then re-compile the quartus project. This inhibits analog mic-in sidetone and line-in bypass mixing.
