18 years agoHelp needed about the DE2 Audio Codec
-------------------------------------------------------------------------------- I set up everything as in the DE2 manual, and use the reference design to play music(48KHZ,wav). But why there i...
18 years agoOn my DE2-70 I don't hear any noise either. If you can reproduce with with multiple good sound samples, I would contact Terasic. It is possible that your board is marginal.
Once I have had to send a Xilinx board back which worked, but the voltage regulator was near melting. The replacement was fine. Marginal boards do happen.
