18 years agoHelp needed about the DE2 Audio Codec
-------------------------------------------------------------------------------- I set up everything as in the DE2 manual, and use the reference design to play music(48KHZ,wav). But why there i...
18 years agohow did you plug in your line in and line out wires? do you use splitters (y-adapaters) or anything? i have a de2-70 and the audio codec works fine for me... Try to remove possible sources of interference.. do you have other wires or power cables near your DE2 board? also check your headset to make sure its not damaged
