15 years agoHelp me! UDP payload inserter problem,urgent!
I've added a UDP payload inserter and padding from the famous project- Offload example. I can send a short message through SDRAM->mux with packets from SGDMA component (TS Multiplexer) input4>...
15 years agoI have solve the problems. I have changed the mulplexer of Ethernet,the orignal code is OK. But now I meet another problems. The Avolon st is 32-bit, but my source data is bytes, the payload count may be 491 or other number which can't be divided by 4. Does anybody have a good ideas to deal with the problems. Pading zero can't solve the problems!!!I think so. Give my best wishes to you
