18 years agoHelp. Hardware tutorial does not run on Cyclone II Starter Dev Kit
Hi, Can anyone help me please. The NIOS IDE will not run the result of the Hardware tutorial on my board it gives me: Using cable "USB-Blaster [USB-0]", device 1, instance 0x00 Paus...
18 years agoHi everybody,
I am having the same problem as ashipm01. I have DE2 educational board and I have upgraded my sotfware to Nios II IDE 7.2 (without license) and Quartus II Web Edition v7.2 too. My problem is that I can't complete the "Nios II Harware Development Tutorial". I followed carefully step by step the tutorial: first of all I created and generated a nios 2 processor with the SOPC builder and programmed via USB-Blaster to the Ciclone II. Then, I started with Nios II IDE. I made a New C/C++ Application using count_binary example and selected the .ptf file generated before. Once builded the project, I select Run as-->nios 2 hardware and after several seconds appears in the console the message: Using cable "USB-Blaster [USB-0]", device 1, instance 0x00 Pausing target processor: not responding. Resetting and trying again: FAILED Leaving target processor paused I have found on the web (http://forum.niosforum.com/forum/lofiversion/index.php/t4116.html) 4 possible solutions to solve it: 1. SOPC-builder > board-settings > change the assignment of your pins from "unassigned" to "assign in Quartus II project" 2. Quartus II > Menu bar: Assignments > "Device & Pin Options" > tab : "Unused Pins" > as input tri-stated. 3. If you only get time-limited.sof, please keep the open core plus window open: do not click the "cancel" 4. Connect your reset button with a toggle switch. If the toggle switch to '0' does not work, try to upload your program but with '1'. I have done steps 2,3 and 4 but I don't know how to specify my board settings with SOPC Builder 7.2! I just can select the device family Ciclone II and I don't know if it is the problem. Would be someone so kind to tell me how to solve it or explain me what I am doing wrong? Thanks for advanced Benjamin
