17 years agoHELP! - Virtualization and the USB ByteBlaster
Hello, This is weird one - I'm sure of it. I also made sure that I didn't miss any other posts that could help me regarding this issue in the forum. I am running linux; Ubuntu 8.04 to be ...
17 years ago --- Quote Start --- I didn't realize this but the 'chkconfig' command isn't supported by Ubuntu. Undeterred I tried the following to brute force install it (borrowed from Ubuntu forums): --- Quote End --- So start the service, manually, for now (until you figure out how things work in Ubuntu/Debian-land) and move on with things. [Long-winded explanation] chkconfig is a "convenience" command anyhow. On most Linux distros, you have an /etc/init.d directory where every server script that "could" run is placed. Soft links (ln -s) are then placed from these scripts into the /etc/rc[n].d directories (n represents the "runlevel"). When you boot your Linux box, it will (by default) boot into multiuser mode....which could be runlevel 2 or 3 (/etc/rc2.d, /etc/rc3.d). [Summary] So, just manually copy the script into /etc/init.d and then create a soft link to S30jtagd (or somesuch) in /etc/rc2.d. Cheers, - Ura P.S. [UPDATE] Here's a pretty good tutorial (http://www.yolinux.com/tutorials/linuxtutorialinitprocess.html) on Linux booting.
