17 years agoHELP! - Virtualization and the USB ByteBlaster
Hello, This is weird one - I'm sure of it. I also made sure that I didn't miss any other posts that could help me regarding this issue in the forum. I am running linux; Ubuntu 8.04 to be ...
17 years ago --- Quote Start --- 1.) IPs - static or dynamic? --- Quote End --- Why would it matter? --- Quote Start --- 2.) I haven't loaded anything into the DE2 (other than preloaded) - do I need to program it with something to be able to program over Ethernet? --- Quote End --- I'm not at all familiar with the DE2, but assume it has built-in USB<->JTAG. Mind you, you're not "programming over ethernet", you're just setting up jtagd (which talks to the USB programmer built into your DE2) on your host, and then allowing remote ethernet connections to this server process. --- Quote Start --- 3.) why didn't the manual, user guide or any of the tutorials not describe this? --- Quote End --- Because it's not DE2 specific, but rather a QII feature. Good luck! Cheers, - Ura
