cchun33
7 years agohad 4 pcs of IC failed testing, pls advise if we can get RMA for return or credit?
Zawani_M_Intel
7 years agoHi cchun33,
To get RMA/credit return, we will need to proceed for ERMA process to understand more about your issue and decision will be made based on the ERMA result/report.
Please tell me the story of this part, how you discovered the failure?
*please do not share any confidential info publicly. If you need to send private document, we will continue our conversation through private message.
Thanks!
Wani
- cchun337 years ago
Hi Wani, Pls continue our communication thro’ this email. Attached pls find our FAR form for this RMA request. Tks & regards Cindy Chun | Snr Engineer, Supplier Quality Engineering [cid:[email protected]] Venture Corporation Limited 5006 Ang Mo Kio Ave 5 | #05-01/12 Techplace II | Singapore 569873 | DID +65 64848311 | Main +65 6482 1755 | Fax +65 6482 0172 | email ; [email protected]<mailto:[email protected]> ü Please consider the environment before printing this e-mail - cchun337 years ago
Hi Wani, Still pending for your reply on the RMA# return, pls advise immediately, tks. Tks & regards Cindy Chun | Snr Engineer, Supplier Quality Engineering [cid:[email protected]] Venture Corporation Limited 5006 Ang Mo Kio Ave 5 | #05-01/12 Techplace II | Singapore 569873 | DID +65 64848311 | Main +65 6482 1755 | Fax +65 6482 0172 | email ; [email protected]<mailto:[email protected]> ü Please consider the environment before printing this e-mail
