Himanshu_Varia's avatar
Himanshu_Varia
1 hour ago
Guidance on Enabling USB Mode in F-Tile PMA Direct PHY IP – Quartus Prime 26.1
I am currently working on USB 3.x data-rate implementation using the F-Tile PMA Direct PHY IP in Quartus Prime for the Agilex 7 device.
In earlier versions of the F-Tile PMA Direct PHY IP, the FGT PMA Configuration Rules parameter provided a USB mode. Selecting this mode enabled several USB-specific interfaces and features, including ports such as:
  • fgt_rx_signal_detect_lfps
  • fgt_tx_pma_elecidle
  • Simplified TX Data Interface
However, in the newer Quartus Prime versions, including Quartus Prime 26.1, the USB option appears to have been removed from the FGT PMA Configuration Rules parameter.
Could you please guide me on how to enable or configure the F-Tile PMA Direct PHY IP in USB mode in Quartus Prime 26.1? In particular, I would like to know whether there is a supported Tcl command, configuration setting, or other method to enable the previously available USB PMA configuration.
I would appreciate any guidance or documentation regarding the recommended procedure for enabling the USB-specific PMA configuration and associated ports in the latest IP version.
Quartus Prime Version: 26.1
HMV
