TakaU's avatar
TakaU
1 year ago
GSRD (Pre-Built Binaries) boot fail Agilex® 7 FPGA I-Series Transceiver-SoC Development Kit
I am currently using the Intel Agilex® 7 FPGA I-Series Transceiver-SoC Development Kit (4x F-Tile)
( DK-SI-AGI027FA Dedvice number : AGIB027R31B1E1V),
I have followed the below website to write SD card binaries,
https://www.rocketboards.org/foswiki/Documentation/AgilexSoCGSRDSIAGI027
and wrote JIC Image( ghrd_agib027r31b1e1vaa.jic) to QSPI Flash successfuly.
JIC program log like the bellow
Info (19094): Erasing flash chip select 0 at device index 1
Info (19096): Programming flash chip select 0 at device index 1
Info (19097): Verifying flash chip select 0 at device index 1
Info (209011): Successfully performed operation(s)
Info (209061): Ended Programmer operation at Mon Apr 22 15:01:40 2024
Info: Quartus Prime Programmer was successful. 0 errors, 0 warnings
Info: Peak virtual memory: 2362 megabytes
Info: Processing ended: Mon Apr 22 15:01:40 2024
Info: Elapsed time: 00:01:51
Info: System process ID: 7314
I set MSEL back to QSPI , start serial terminal and then power up the board,
but no response on the serial terminal (speed : 115200).
Before download JIC program, I observed some message on serial terminal.....
so it may not serial terminal setting.
Is there anything wrong i made with GSRD with Pre-Built Binaries boot?
    • TakaU's avatar
      TakaU
      Thanks a lot of your reply.
      Now DK-SI-AGI027FA is up and running.
      Probably I did use wrong version jic file.
      ( this is just FYI....
      I used screen as a serial communication program.... but it did not work well.
      For example, Boot message are freezed in middle of boot process,
      so I setup minicom that GSRD document prefer.
      Then the Board boot up, and everything is fine now.)
  • Jeet14's avatar
    Jeet14
    Thanks your confirmation.
    With that, I now transition this thread to community support.
    Thank you.
    Tiwari
